Best Setting to Burn DVD
Dean Longfield
on Feb 21, 2012 at 7:25:28 pm
I have FCP Studio 3, with FCP 7 and DVD SP 4 and Compressor 3.5. I shoot in XDCAM EX 1080 60i.
However I edit the XDCAM EX footage in an SD wide screen timeline. If I Export to QT Movie with current settings and use that .mov file to import into DVD SP4, I get some artifacting on the DVD burn to the point where I can't give that to clients.
I did try Share > DVD , which made an MPEG-2 which i imported to DVD SP4 and it looked considerably better.
I have tried Share > Send to Compressor previously and burned DVD in Compressor, but did not notice
much quality difference than the EXPORT > QT Movie method. Also if I tried to take the file made by Compressor and bring it into DVD SP 4; only the video would enter DVD SP 4, not the audio, (the audio did not automatically follow). If I tried bringing in the audio separately the sync was off in the final product.
So I'm a bit perplexed. As of right now the best method I've been able to find is FCP Timeline > Share w/DVD setting > DVD SP4.
I'm about to try Apple Pro Res 422. ( Share > Apple Pro Res 422) & Export > Settings: Apple PrRes 422 NTSC 48khz [Anamorphic] ).
Any comments or suggestions would be helpful and appreciated. Thanks.
Dave LaRonde
Re: Best Setting to Burn DVD
on Feb 21, 2012 at 7:38:53 pm
[Dean Longfield] "I shoot in XDCAM EX 1080 60i.
However I edit the XDCAM EX footage in an SD wide screen timeline."
I can think of no good reason to do so.
Edit your footage in a Prores 422 2080i timeline, export a self-contained quicktime, open the file in Compressor and use the presets to make the mpeg2 and ac3 files for DVD authoring; don't forget to author as 16x9. Your DVD ought to look great.
Okay, as great as highly-compressed SD video can look compared to pretty-highly-compressed HD video.
Dave LaRonde
Sr. Promotion Producer
Dean Longfield
on Feb 21, 2012 at 7:42:30 pm
Thanks Dave. I'll run some tests using that method.
Dean Longfield
on Feb 21, 2012 at 7:39:30 pm
I just tried, from an SD - FCP timeline : Share > Apple Pro Res - which made a Apple ProRes 422.mov, which I brought into DDVD SP 4 and the burn came out looking like QT Movie burn (too many artifacts/pixelization).
Traditionaly I had always burned DVD's using an MPEG-2 source file and it seems that that is still the way to go, and from FCP 7 it appears that using Share > DVD are the settings that will accomplish the MPEG-2 source file.
If there is a way to obtain BETTER quality than what I've described above, please let me know.
Thanks !
Dave LaRonde
on Feb 21, 2012 at 7:42:34 pm
Please read what I wrote again, and this time please read it with an eye toward comprehension.
Dave LaRonde
Shane Ross
on Feb 21, 2012 at 8:44:07 pm
Well, you had a small typo in that first post..."Edit your footage in a Prores 422 2080i timeline"
It should be: Edit your footage in a ProRes 422 1080i timeline. FULL HD quality timeline. THEN export for DVD.
Shane
Little Frog Post
Dean Longfield
on Feb 21, 2012 at 9:26:34 pm
Hi Dave,
i sent my second post as a follow up to my first post NOT as a response to your answer/suggestion..
Apparently I was writing my follow-up and you were writing your suggestion at about the same time,
....anyway, I did subsequently read your post and appreciate the suggestion.
Any confusion there of is more to do with the nature internet communication and timing than anything else, (not comprehension or a lack there of).
Have a nice day.
Dave LaRonde
on Feb 21, 2012 at 9:28:28 pm
I hope you get a good-looking DVD.
Dave LaRonde
