Pro res 422 render problem!
michael unger
on Feb 21, 2012 at 2:01:41 am
My issue is the following:
My footage is in Pro Res 422 (1920x1080). My sequence is Pro Res 422 (1920x1080) with Unlimited RT. Every time i make a cut i have the render out the orange or else i get a slow playback. What am I doing wrong?
Shane Ross
Re: Pro res 422 render problem!
on Feb 21, 2012 at 3:03:24 am
Multicam? Have a filter on the footage? resized? Somethings not right. Not matching up exactly
Shane
Little Frog Post
Erik Lindahl
on Feb 21, 2012 at 12:22:59 pm
Also check that if the media is interlaced or progressive and make the same change to the timeline. If the ProRes-files originate from an odd source - double check their frame rate as well. I've seen 24.xx FPS when dealing with 25 fps footage for example. This is something FCP won't like.
