FCP - cinema tool fail
paolo zuniga
on Feb 20, 2012 at 11:02:07 pm
Hi, I recently tried to open cinema tools in order to slow the frame rate of a video I had shot at 60fps. Upon opening, the program immediately failed after in bounced around in my dock. I use a macbook pro and the program came with my FCP. I've used it before but this time it seems to not be working at all. Any insight on what might be causing this error?? Final Cut works just fine.
I recently upgraded to Lion (which I regret) and I'm wondering if that has anything to do with it. Cinema Tools seems to be version 4.0. Could this be the issue?
Neil Patience
Re: FCP - cinema tool fail
on Feb 21, 2012 at 1:03:51 am
I have seen other posts that suggest Cinema Tools 4.0/4.01 is not compatible with Lion.
For example here
and here
I am not sure which version of FCP had Cinema Tools 4.0 however I am using FCP V 7.03 which has Cinema Tools 4.5.1 which does run fine under Lion.
best wishes
paolo zuniga
on Feb 21, 2012 at 6:25:33 pm
It def seems to be Lion that is messing up some of my programs. I'm considering going back to Snow L. Thanks for your help!
© 2018 All Rights Reserved
