I need to make a IMX file for Avid from my XD Cam EX 1 footage but how to do ?
tony helsloot
on Feb 20, 2012 at 1:49:59 pm
Hi Everybody.
I'm new here and hope to help others too.
I'm a Nature filmaker for 25 years and now working with FCP for many years.
I need to help the Turkish TV with a clip they want from me ,my footage is in XD Cam 1080 30 P format
They want the IMX format from me,but I tried everything I can't do it ,they don't work with MOV files and that's where is become a grey area for me.
The have Avid and need the following.
SD file Format : MXF - IMX 30
Video Format : MPEG 2 ( 4:2:2 )
Data Rate : 30 Mbit/s
Resolution : 720x576 @ 25fps
Audio configuration:
CH 1/2 : Stereo L/R (Full Mix) CH 3/4 : Stereo M&E
HD file Format : MXF 50
Data Rate : 50 Mbit/s
Resolution : 1920x1080 @ 50i
I hope somebody can help.
Is there a plug inn for compressor wich may do this ?
Any tips much appreciated .
Rafael Amador
Re: I need to make a IMX file for Avid from my XD Cam EX 1 footage but how to do ?
on Feb 20, 2012 at 3:33:57 pm
You need to make two sequences using the Easy setups. One needs to be IMX-30 and the other XDCAM HD-422. Then use the "Export to XDCAM" option and select MXF (no MP4).
However you will have to split the audio channels because they can't be stereo.
rafael
http://www.nagavideo.com
tony helsloot
on Feb 20, 2012 at 4:49:21 pm
Thanks Rafael,I tried all you said but i can't find the option and select MXF ?
Any idea what I do wrong ?
Thanks ever so much
Tony
Warmest regards,
Tony Helsloot
See our DVD's at
https://www.worldnaturevideo.com
See my films at :
http://www.youtube.com/user/IsisVisuals
And please be my friend at
http://www.facebook.com/naturedvds
Rafael Amador
on Feb 20, 2012 at 5:13:33 pm
Hi Toni,
You need the SONY Transfer tool installed in your Mac. Then in FCs menus File > Export, down the window you have "Export to XDCAM" option.
rafael
tony helsloot
on Feb 20, 2012 at 6:14:26 pm
Thanks for the screen shot,so i downloaded the XDCAM EX
Log and Transfer With Final Cut Pro PDZK-LT1 and installed it but ,still no show like in your screen shot,is very strange ,i restarted and then install again,no succes .
On the I Mac even worse ,I run Lion and FCP 7.03 and it won't even install at all.
So is becoming a bit tricky from here I guess ?
Any idea's :)
Tony
Warmest regards,
Tony Helsloot
See our DVD's at
See my films at :
Rafael Amador
on Feb 20, 2012 at 6:29:05 pm
Is possible that you also need to install the SONY Clip Browser.
rafael
tony helsloot
on Feb 23, 2012 at 5:31:42 pm
OMG still not working,I going to try it on another system,hope if i have more luck :)
Thanks I keep ya posted.
Warmest regards,
Tony Helsloot
See our DVD's at
See my films at :
