Single Blade Tool Not Working In Final Cut Pro 7
Dom Rolls
on Feb 19, 2012 at 12:02:41 am
For some reason my single blade tool in final cut pro 7 is not working. I press "b" (once) and the icon shows up as a single blade but, when I trim the clip it acts like a double blade and trims both the clip and the audio. I don't know if this is because my Final Cut Pro is messed up or if its something I can simply fix. Please help me solve this problem and thanks in advance for any advice.
David Roth Weiss
Re: Single Blade Tool Not Working In Final Cut Pro 7
on Feb 19, 2012 at 12:31:38 am
You have to unlink the audio and video first by clicking on the icon on the upper right that looks like little chain.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
http://www.ProMax.com
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Dom Rolls
on Feb 19, 2012 at 12:51:31 am
Thanks I'm an idiot
Michael Griggs
on Feb 19, 2012 at 4:30:47 pm
You can also hold down the option key while you use any tool. This enables you to select any clip/item that is otherwise linked without un-linking it. And it stays linked after you deselect.
