Converting from 720x486 or 480 to square pix for view on computer online portfollio.
Brad Surround
on Feb 18, 2012 at 12:38:30 am
I am in the middle of taking all of our Broadcast work/ Music Video work and preping it to be viewed online . Now I know that if I just upload it in the 720X486 or 480 ratio it will look stretched. I am using Compressor to do my compression and resizing, could some one tell me what the correct size should be to convert my projects so they will not look stretched when viewed online ? Again I have 2 sizes 720x486 and 720x480. Thanks !
Michael Gissing
Re: Converting from 720x486 or 480 to square pix for view on computer online portfollio.
on Feb 18, 2012 at 12:56:33 am
It is easy to calculate a 16:9 ratio for any frame size. Take the vertical pixel resolution, multiply x 16 and then divide by 9. A slight round up or down to avoid decimals is OK.
So 486 x 16 = 7776 / 9 = 864 .
Jason Brown
on Feb 22, 2012 at 3:39:35 am
Michael,
First off, you are assuming that these videos are 16:9.
I've dealt with this for years and I have some comments that I think are relevant to the conversation.
First off, I think it's important to note that the 6 pixel difference between 480 and 486 is so minor that in my testing...you can't visually see any scaling difference.
Working on AVID back in mid 2000's, if you exported 16x9 D1 (720x486) from an AVID meridien at square pixels, you'd get a resulting file at 864x486. Working in premier years later, I found 16x9 DV (720x480) footage exported out at square pixels to come out at 853x480. It's important to note that things seem to have changed around CS3 and CS4. I believe it was CS4 that introduced a new PAR 1.21 instead of the commonly used 1.2 that we had been historically using. Not a huge change, but it seems to have affected things a bit in the translation, I don't deal in SD anymore, but I just opened Photoshop CS5.5 and the D1 Widescreen square template is 872x486.
My formula that I've been using for several years and seems to hold up pretty well:
The 16x9 square pixel translation of 720x480 is 853x480
The 16x9 square pixel translation of 720x486 is 864x486
The 4x3 square pixel translation of 720x480 is 640x480
The 4x3 square pixel translation of 720x486 is 640x480
This is what I use and it has served me well in dealing with archival sources and cataloging older content in a viewable format and aspect.
-Jason
Michael Gissing
on Feb 22, 2012 at 3:49:45 am
Jason, I think it fair to assume the original is 16:9 when Brad said his 720 x 486 looks stretched and wanted to know what settings so it didn't look stretched.
The simplicity of using maths to calculate 16:9 is that it works. The web doesn't care if it is a few pixels either way.
Jason Brown
on Feb 22, 2012 at 4:10:33 pm
[Michael Gissing] "720 x 486 looks stretched"
I look at 4x3 content at 720 and think it looks stretched... But good point...
Jason Brown
on Feb 22, 2012 at 4:13:12 pm
[Michael Gissing] "16x9 square pixel translation of 720x486 is 864x486 and you meant 854x486"
no, if you multiply 720 x 1.2 PAR, you get 864. Not sure why DV seems to be 854...but in the research I've done, everyone seems to be using that number with DV, but 864 with D1.
Brad Surround
on Feb 22, 2012 at 6:44:04 am
Bravo !! Bravo !! THAT was the answer I was looking for. Well...you all were really a great help but this posting is exactly what I needed. Thank you all !!
Dave LaRonde
on Feb 18, 2012 at 2:35:10 am
For standard-definition video like this -- NTSC to boot -- I recommend that you create 640x480 files. Use custom settings. Life will be good.
Dave LaRonde
Sr. Promotion Producer
Hans Damkoehler
on Feb 18, 2012 at 3:30:41 pm
Just make sure to de-interlace or you will be hating life.
Hans Damkoehler
VideoBloom, Inc.
Senior Video Editor/Producer
Web: hd-editor.com
Twitter: hd_editor
FaceBook: http://www.facebook.com/hdeditor
