Final Cut Pro export: white sections, freezing, pixelated, etc.
Charles House
on Feb 16, 2012 at 8:42:08 pm
I am exporting a series of videos for a client. I shot a sweet 16 birthday for them, and I have several videos. A few are shorts, some are longer (20 minutes or so). I had 3 cameras and I cut between them. Throughout, the videos will cut to white sections, freeze on a frame for long periods, pixelate out after freezing, etc. The audio remains intact. Here is one of the videos.
http://www.youtube.com/watch?v=g-ienrOJm5g#t=06m00s
In this instance, at the end of the video, I faded out to black, and that's where the issue starts in the export. In other videos, it seems to be without reason, but in all of them, if I change the opacity to fade in/out of a clip, either to another clip or to black, it does this.
What is the issue?
Jerry Hofmann
Re: Final Cut Pro export: white sections, freezing, pixelated, etc.
on Feb 17, 2012 at 2:29:36 am
What format did you shoot, and what are your sequence's settings?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Charles House
on Feb 17, 2012 at 2:36:01 am
Hi Jerry,
I had three camera; two T3is shooting 1920x1080 24p, and the backup camera was an HVX200 shooting 720 30p. Yes, I did mix frame rates in a few videos, but that doesn't seem to be the issue, as all of the videos, even the ones where the HVX footage was never used, have these issues. The sequence settings are for the T3i footage.
You can see here where the issue comes up in this video, which is only T3i footage. At very end of the video, I faded the opacity down to black; that's where you can see the issue. In other videos, it happens during places without any filters, transitions, or other alterations to the footage. However, it does seem to happen every time there's an opacity change, as well.
Jerry Hofmann
on Feb 17, 2012 at 2:51:53 am
Well that's the problem... the t3i shoots H.264 video files, and those aren't supported in FCP 7 (and not actually in X either - just seems like it). Thus your uglies...
You need to transcode the footage from those cameras to ProRes before you edit them. Now you need to transcode the shots you used to Pro Res, edit them in a ProRes sequence, and you'll not see the problem when you export.
Jerry
Current DVD:
Charles House
on Feb 17, 2012 at 3:00:55 am
I know several people who shoot with T3is and don't have this issue?
What do I do now that I've edited everything?
David Roth Weiss
on Feb 17, 2012 at 3:25:19 am
[Charles House] "I know several people who shoot with T3is and don't have this issue?"
You'd better ask those people what they're doing, because no one here on the Cow can edit h.264 files without issues. Jerry told you right.
[Charles House] "What do I do now that I've edited everything?"
You could try to transcode to files that match your other cameras and relink to the new files, but as they say, your mileage may vary. You may have to eyeball match if relinking isn't frame accurate.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
http://www.ProMax.com
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Charles House
on Feb 17, 2012 at 3:27:36 am
Could I re-export all of the cuts as individual clips, transcode all of the new individual clips it makes, and then re-import them into FCP and lay them back out again?
I called around. Everyone I know who works with a DSLR now switched to Adobe. Coincidentally, none of them know what "transcoding" is.
David Roth Weiss
on Feb 17, 2012 at 3:39:17 am
[Charles House] "Could I re-export all of the cuts as individual clips, transcode all of the new individual clips it makes, and then re-import them into FCP and lay them back out again?"
Yes, that's one way of doing it. If you are cutting in a DVCPro sequence, keep in mind that exporting those clips as self contained files will mean that they are already going to be DVCPro, because they will match the codec of the timeline. The problem is, you may encounter the exact issue you had before when trying to export.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Charles House
on Feb 17, 2012 at 3:43:45 am
I appreciate your input... but I kind of am missing the point of what you're saying. It seems that doing something that arduous but winding up where I am right now would be... pointless.
In essence, without re-editing this entire project, how can I fix this issue?
David Roth Weiss
on Feb 17, 2012 at 4:10:34 am
[Charles House] "In essence, without re-editing this entire project, how can I fix this issue?"
You must first try the techniques I've already mentioned. Transcode and try to relink first. Then try eyeball matching if relinking won't work. That's what I'd do...
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Charles House
on Feb 17, 2012 at 4:25:20 am
Thanks for the info. I guess I won't know if it "works" until after I export; I had no trouble editing this content.
How do I transcode? Obviously, by my dumbfounded responses, I've never done it.
I'm not sure what you mean by eyeball matching, or the issue that'd necessitate it. Sorry for seeming so daft.
Jerry Hofmann
on Feb 17, 2012 at 4:26:28 am
Nothing to do other than what's suggested.
If you do as suggested by David, you'll end up getting an export that doesn't behave like you're seeing. You won't be back where you are now.
BTW. No NLE edits h.264 files natively AFAIK. FCP X would have not required you to manually transcode. It does it automatically...
Jerry
Current DVD:
Charles House
on Feb 17, 2012 at 5:24:48 am
Thank you for the post.
So give me a quick rundown on what I'm trying. I'll do it in the morning, and I'll post the results.
I really appreciate your input and patience.
David Roth Weiss
on Feb 17, 2012 at 6:21:49 am
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
