Jittery Video With A Timebase Of 25
Patrick Morrow
on Feb 15, 2012 at 9:35:55 pm
A completed wedding just still does not look right. It says the timebase is 25 and has the following
HD 1440 x 1080
Quicktime:
DVC Pro HD 1080i 50
Lower Field Dominance
Can anyone help me get good stable non-jittery video out of this mess?
THANKS!!!!!!!!!!!
Daniel Ludwig
Re: Jittery Video With A Timebase Of 25
on Feb 15, 2012 at 9:45:35 pm
no 1 hit for errors in video: wrong field dominanz!
1. HD1440x108 = upper first
2. DVC PRO HD = upper first
by spec
so why you´ve chosen DVC PRO HD as lower field first, as it is upper first?
cheers
danny
Patrick Morrow
on Feb 15, 2012 at 9:47:20 pm
Oh and Toast Titanium says my video is in PAL, could that be right?
Shane Ross
on Feb 15, 2012 at 10:07:31 pm
Your video IS in PAL. 1080i50...1080p25...720p25...that's PAL. PAL is 25fps. NTSC is 30fps.
Shane
Little Frog Post
Patrick Morrow
on Feb 16, 2012 at 10:32:22 pm
Is there a way Shane to fix the jitter and get it back to NTSC? Help!!!
Shane Ross
on Feb 16, 2012 at 10:41:20 pm
BACK to NTSC? It wasn't NTSC to begin with. It is PAL. Your footage is all PAL.
Shane
Little Frog Post
