Cut Out Text Effect
Garret Hernandez
Cut Out Text Effect
on Feb 14, 2012 at 6:48:19 pm
Trying to figure out how to Make my text look cut out/ transparent so that the clip is visible through the text. Any ideas?
Here is an example in the lower text:
Dave LaRonde
Re: Cut Out Text Effect
on Feb 14, 2012 at 7:21:48 pm
This is easily done in After Effects. Perhaps Motion as well, although I'd have to research how to do it.
Got either?
Dave LaRonde
Sr. Promotion Producer
Garret Hernandez
on Feb 14, 2012 at 10:32:05 pm
I have after effects, Can you help me?
Dave LaRonde
on Jul 24, 2013 at 2:32:41 pm
In After Effects, use the desired text layer as a track matte for the video to fill in the text. That's it. Pretty simple.
Dave LaRonde
Former Sr. Promotion Producer
jerry wise
on Feb 14, 2012 at 10:53:54 pm
real easy in Final Cut 7. bottom layer can, lets say, be color bars. next layer up is your text. next layer up is the image to fill in the text. select the top layer and right click to reveal drop down. then select composite mode and select travel matte alpha. your done.
if you want to add a drop shadow to your text then duplicate your text layer underneath your original text layer and add your drop shadow. piece of cake. and if you want to move the whole mess around the screen then select all your layers except for the background color bars layer and nest them.
Garret Hernandez
on Feb 14, 2012 at 11:11:11 pm
Thank you so much.
A few questions:
By "image" do you mean the clip i want to fill the text
And what is the importance of the bottom layer, where you used "color bars"
jerry wise
on Feb 15, 2012 at 5:44:16 pm
by "image" i mean what ever material you want to be seen inside the text letters...be it a still pic or video.
the bottom layer is the background that your filled text would appear on. you dont have to have a background...it was just an example.
Nick Callan
on Jul 22, 2013 at 11:36:33 pm
Is there a way to do this for a white background?
The method as described will result in a black background, right?
Nick.
