i need to know what's the Technique?
Matta Roushdy
on Feb 14, 2012 at 12:46:14 pm
Hello every Body I'm working as a senior Editor and motion graphic designer, i want ask about this song
I just ask on how to make this effect on the movement of the singer?
what's the Technique and what is the software?
Thanks for Help
Matta Roushdy
adam taylor
Re: i need to know what's the Technique?
on Feb 14, 2012 at 1:00:23 pm
its called "stop frame animation" - its not software driven, its an in-camera effect created by shooting sequences of thousands of still frames, and moving slightly between each frame.
Thats how you get her clothing to be animated as well as her hair.
It also helps to photograph a pin sharp image on every frame without motion blur.
To replicate a similar effect in video, i would remove every other frame, and then duplicate every frame that is remaining. Traditional animation is often done using "doubles" ie, for every frame they shoot two images, which is what gives the animation its staccato appearance.
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UK
http://www.sculptedbliss.co.uk
My YouTube Animations Page
Rafael Amador
on Feb 14, 2012 at 1:29:55 pm
[adam taylor] "To replicate a similar effect in video, i would remove every other frame, and then duplicate every frame that is remaining. Traditional animation is often done using "doubles" ie, for every frame they shoot two images, which is what gives the animation its staccato appearance."
Yeap.
Speed up the footage 200%, then slow down to 50% without frame blending.
rafel
http://www.nagavideo.com
Bret Williams
on Feb 14, 2012 at 6:49:22 pm
This is what the "strobe" effect is for. Just apply and it freezes every x frame for x frames. If it's set to 4 for example, it plays frame 1 four times, then frame 5 four times, etc.
David Eaks
on Feb 14, 2012 at 2:04:13 pm
Ha Ha, static, bars and tone at the end. And it's all Jelly Belly's.
Is this done with multiple layers? In the beginning when she is walking past the trees, the foreground trees move by faster than the background trees as they would in real life. It seems like it would be quite time consuming to create that 3d effect without a separate layer for the tree going by. It looked like one layer to me...
adam taylor
on Feb 14, 2012 at 2:05:45 pm
whoever said Art was fast?
Adam Taylor
Oldham, UK
David Eaks
on Feb 14, 2012 at 2:14:54 pm
That's not what I meant, I was thinking it's pretty impressive to pull off. Painstakingly moving one by one in a single layer. I had fun watching it, so the artist did a good job...
I would be less impressed if it was layers.
Shane Ross
on Feb 14, 2012 at 5:33:55 pm
This is straight up animation. Take a picture...move...take a picture...move...take a picture...move.
All done in camera on set. All practical.
Shane
Little Frog Post
Bret Williams
on Feb 14, 2012 at 6:43:00 pm
There's a link to the making of video when it's finished. It's a good watch. The first 20 seconds pretty much answers all the questions.
Richard Herd
on Feb 14, 2012 at 7:43:08 pm
It is fast. You use multiple layers in After Effects (for example) and then place them in z-space and then move a camera right to left.
Mike Raff
on Feb 14, 2012 at 8:31:16 pm
Watch the "making of" video and you'll see what's involved:
22 months
1,357 hours
30 people
2 ladders
1 still camera
288,000 jelly beans
Mike Raff
Richmond, VA
Bret Williams
on Feb 14, 2012 at 8:42:58 pm
There wouldn't have been any jellybeans left at the end if I was on set.
Rafael Amador
on Feb 15, 2012 at 2:11:38 am
Carps, I just saw the "making of".
I thought was done with chroma-key and some funny graphics effects.
Amazing.
rafael
adam taylor
on Feb 15, 2012 at 10:43:47 am
its not often i get to say "told you so!"
Adam Taylor
Oldham, UK
