Any tips for creating sharp (not fuzzy or blurry) Titles in FCP?
Lawrence Richards
on Feb 14, 2012 at 12:54:01 am
Hey All,
As the subject line says, I am wondering if anyone can offer any tips for how to make simple titles look really sharp? Are there certain colors/fonts to stay away from? Any particular settings? The reason I ask is because often the titles look kind of fuzzy or blurry.
Thank you!
Thank you!
Larry R.
Florida
Shane Ross
Re: Any tips for creating sharp (not fuzzy or blurry) Titles in FCP?
on Feb 14, 2012 at 1:26:38 am
What are the sequence settings that you are working with? Size...dimensions...codec (codec is key!)
Shane
Little Frog Post
Lawrence Richards
on Feb 14, 2012 at 1:33:38 am
Hey Shane,
I'm not sure of the codec of the timeline as I let FCP match the settings of the raw footage. I can tell you the size and codec I converted it to though.
Thank you!
Larry R.
Florida
Shane Ross
on Feb 14, 2012 at 1:38:28 am
Open the SEQUENCE SETTINGS...that'll tell you.
And you don't know the codec/size of the footage you are working with? That's info you need to know.
Shane
Little Frog Post
Shawn Bann
on Feb 14, 2012 at 2:23:52 am
I've always found FCP's titles to leave much to be desired.
Red text can be a nightmare (across all codecs)
The best method I have found is using AE/Photoshop.
