Setting the LOg & Transfer to ProRes LT for EX3 Footage?
Sascha Engel
on Feb 13, 2012 at 8:22:39 pm
a very general question: Can I set in the Log & transfer window inside FCP in the Preferences somehow the settings in a way, that FCP transfers the EX Footage to ProRes LT and not to XDCAM EX Codec?
Thanx a lot.
Sascha
Shane Ross
Re: Setting the LOg & Transfer to ProRes LT for EX3 Footage?
on Feb 13, 2012 at 11:49:44 pm
Nope. XDCAM only comes in as XDCAM. If you want it to be ProRes...you gotta use the Media Manager to convert, after you import. Two stage process.
Shane
Little Frog Post
Sascha Engel
on Feb 14, 2012 at 6:48:50 am
Hi Shane,
Thanx for the answer.
Could you tell me in a nutshell what's the quickest and safest way to do that second step in the Manager?
Since I have 1500 clips, I hope it's a rather simple and self repeating one?
Greetings,
Sascha.
Rafael Amador
on Feb 19, 2012 at 12:37:32 pm
Sascha,
Why do you want PRLT instead of EX footage?
Edit in EX and before exporting change your sequence codec to Prores or even PRHQ, or edit the EX stuff directly on an PR sequence.
rafael
http://www.nagavideo.com
