how to do super fast cuts between two clips?
sean miller
on Feb 10, 2012 at 1:04:34 pm
Hi Guys, was wondering if anyone knows of a quick method to do really fast cuts between two clips (aside from frame by frame with the blade tool) in fcpx
this video has the technique used loads :
Juan Salvo
Re: how to do super fast cuts between two clips?
on Feb 10, 2012 at 5:28:30 pm
In all likelihood that video just did a bunch of edits. One quicker was of doing it is laying one shot over the other and then using the razor tool to cut holes in the shot on top. If you want to do it back on forth in a fixed number of frames you can use the blink filter. You could even keyframe the on/off duration to change the rate of cutting.
Jerry Hofmann
on Feb 10, 2012 at 6:09:31 pm
A mulitclip might work, if the timing of the shots would allow for it. That you could cut pretty fast.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
james Brown
on Jun 26, 2012 at 6:02:44 pm
Please help me....can you show me steps in doing this...my email is:ucpro12@yahoo.com
Thaks.
