Uh... certain functions no longer going into Undo Queue
Ben Insler
on Feb 9, 2012 at 9:42:13 pm
So just recently, my FCP no longer incorporated add/delete filters into my undo queue. So if I add a filter to a clip by accident, I can't press undo and have that effect be removed. Or, if I delete an effect by accident, I can't undo to put it back. Even worse, let's say I select 10 clips and remove all filters, but really only meant to select 9. I can't undo and recover the filters for the clip I didn't mean to select. This is killing me with in-edit color correction.
Anyone know what's causing this?
FCP 7.0.3
OS X 10.6.8
BlackMagic DeckLink HD Extreme 3
A few reliable plugins (Magic Bullet, Nattress)
Edit is sync sound and multicam
Now that I think about it - the only thing I've changed recently was installing some transitions from filmimpact.net (they have a nice blurred push). Anyone have bad luck with them? The transitions are already in my edit, so I haven't removed them from FCP yet.
Thank you!!!
