Recommended Timeline Settings/Codecs for P2 footage
Lawrence Richards
on Feb 6, 2012 at 1:06:06 pm
Hello!
When placing my clips in the timeline, is there a "best" setting to choose or should I just let FCP match the settings automatically?
Other than my choosing what to shoot (i.e. 720p/24fps or whatever in the camera settings) I didn't realize I was choosing anything that would translate to something like a particular timeline setting.
Thank you!
Thank you!
Larry R.
Florida
Shane Ross
Re: Recommended Timeline Settings/Codecs for P2 footage
on Feb 6, 2012 at 4:25:23 pm
[Lawrence Richards] "When placing my clips in the timeline, is there a "best" setting to choose or should I just let FCP match the settings automatically? "
Let FCP make the sequence match the clip settings.
[Lawrence Richards] " I didn't realize I was choosing anything that would translate to something like a particular timeline setting."
If you shoot DVCPRO HD, FCP will make a sequence to match...as it works with DVPRO HD native. If you shoot AVCIntra, then you have two options...bring in Native and edit on a ProRes timeline (as there are no AVCIntra sequence settings), or bring in the footage as ProRes and then edit prores....letting FCP set up the sequence for you.
Shane
Little Frog Post
