Exporting setting the data rate
Martin Robbins
on Feb 5, 2012 at 2:43:49 pm
Hello,
When exporting the 1st draft of a video for a client to see, I set the data rate in FCP to 2000 generally, length of the video varying this slightly.
I was just wandering, if I were to send to Compressor and export via that, is there a way of setting the data rate?
Thanks in advance,
Martin Robbins
http://www.martinrobbinsmedia.com
Rafael Amador
Re: Exporting setting the data rate
on Feb 5, 2012 at 4:02:13 pm
[Martin Robbins] "When exporting the 1st draft of a video for a client to see, I set the data rate in FCP to 2000 generally, length of the video varying this slightly.
I was just wandering, if I were to send to Compressor and export via that, is there a way of setting the data rate?"
If you are talking about H264, yes, you can set it in Compressor, but go to compressor only if you need to change the size, de-interlace or change the time-base, otherwise QT Conversion will do the same job.
rafael
http://www.nagavideo.com
Thomas Morter-Laing
on Feb 6, 2012 at 4:15:02 pm
Whilst we're on the topic, with newer software's being constantly updated, and compressor starting to look a little archaic, is compressor still the best compression software to use (if hardware isn't an option)? How does it compare in terms of things like quality and downscaling/upscaling to programs like mpeg streamclip?
Tom Morter-Laing
Twitter- @TomTheEditor
_________________________________________________
Editor, Certified Apple Product Proffessional, 2010
Equipment (not for 'bragging', but in case it's relevant to future posts :D): Canon 7D, with Rode NTG2.
iMac 27" intel i7 3.4GHz, 12GB RAM, ATI HD 6970M [2GB GDDR5], 2x G-Tech G-RAID (0) 2TB over Thunderbolt via Sonnet Echo ExpressCard/34 Thunderbolt adapter and Tempo™ SATA ExpressCard/34. Elgato Turbo H264HD.
Martin Robbins
on Feb 6, 2012 at 7:39:56 pm
Yeah it's always to H264 @this stage. Where in compressor can I set the data rate to 2000?
Rafael Amador
on Feb 7, 2012 at 9:09:35 am
In the Inspector > Video Setting.
Click on "Setting" to open the compression window and select Data rate limit.
Set Keyframes AUTO and Multipass.
rafael
