A Series of Stills..Trick to adjusting lengths all at once?
Blake Porter
on Feb 4, 2012 at 2:38:10 am
Seems silly... I've always done this by hand, but there must be a faster way to adjust the lengths of a series of stills...
Example: The default length for a still image is 10sec. I have 50 stills, I need each at 10 frames length each.
Michael Griggs
Re: A Series of Stills..Trick to adjusting lengths all at once?
on Feb 4, 2012 at 4:23:26 am
You can change the default length that stills import at in your user preferences (alt+Q). Set it to be however long you want them, then just reimport.
Blake Porter
on Feb 4, 2012 at 4:27:36 am
OK I can see that. .. but not in these situations, where piles of different stills need to be custom adjusted.
Thanks for the input Michael!
Neil Ryan
on Feb 4, 2012 at 5:15:39 am
IF you're in FCP 7 and you're trying to do what I think you're doing...
- Select all the stills.
- Right-Click
- Select 'Duration'
- Enter the desired new duration.
Note: I think it requires them all to be the same duration to begin with. And...
Altering the duration of a clip/some clips this way can push later clips down in the timeline.
I usually do this to clips (stills) in a sequence of their own, or cut/paste them to the end of the Timeline, make the adjustment, then cut/paste them back where I want them.
Hope this helps.
Neil.
Blake Porter
on Feb 4, 2012 at 5:19:02 am
That's it my friend! thank you very much!
