Quicktime Compressor
Jimmy Stephans
on Feb 4, 2012 at 1:15:41 am
I've been playing and testing in FCP to Export using Quicktime.
When I do (to Quicktime Movie) I notice on the Size dropdown menu there are these two options.
1920 x 1080 HD
and
HD 1920 x 1080 16:9
Whats the difference?
And, if there is a difference... which should i use if my final target is QT movies that are downloaded and played from hard drive?
Thanks in advance,
Jimmy
Hariharan Swaminathan
Re: Quicktime Compressor
on Feb 4, 2012 at 2:33:59 am
Hi
1920 x 1080 HD is the same as HD 1920 x 1080 16:9. Only difference is the aspect ratio. 16:9 should be used if you have applied lightbox in your footage. I would say go with the first option to get the full frame of the shot where as if you use 16:9 your actual frame will be cropped.
It's better to apply both profile. It's just drag and drop in compressor. See which one you like.
Hope it helps
HARIHARAN SWAMINATHAN
http://www.filmmaker.me
| Hariharan Swaminathan |
photographer | film maker
http://www.ihariharan.com
http://www.vimeo.com/ihariharan
http://www.youtube.com/ihariharan
Jimmy Stephans
on Feb 4, 2012 at 4:20:20 am
Thanks. I think I have it now!
