Exporting footage with colour solid masks.
Michael Coates
on Jan 31, 2012 at 3:33:15 pm
Hello once again, different question here, I have a clip 15 seconds in length that contained images in the background I didn't want in. I was able to add a solid colour to these parts of the image and 'mask' them - essentially deleting them out.
It looks fine but I'm curious now, can I export with the masks in place without losing quality to the overall image. If I just export as current settings will it be essentially the same file but with the 'masking' rendered on top?
Thanks for reading
Michael
Rafael Amador
Re: Exporting footage with colour solid masks.
on Jan 31, 2012 at 5:08:59 pm
[Michael Coates] "It looks fine but I'm curious now, can I export with the masks in place without losing quality to the overall image. If I just export as current settings will it be essentially the same file but with the 'masking' rendered on top?"
The whole picture will be processed, but if you are using a good codec, the un-masked areas won't degrades.
If you export Uncompressed, you will keep the original pixel.
rafael
http://www.nagavideo.com
Michael Coates
on Feb 1, 2012 at 12:14:08 am
Thank you very much, exported uncompressed with the colour masks and it looks the same to me without the annoying and intrusive objects which I covered up.
Superb :)
