Using one frame from footage as a photo
Sheree Day
on Jan 31, 2012 at 9:39:13 am
Is there any easy way to select just one frame from your piece of footage and use it on the timeline like a photo, and perhaps be able to zoom in and out of it too?
Jerry Hofmann
Re: Using one frame from footage as a photo
on Jan 31, 2012 at 11:22:15 am
Won't be able to zoom in and out without it tearing up the picture a bit, but yes. Park your playnead on the frame you wan to freeze and type shift+n. A freeze shows up in the Viewer to edit into the sequence.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Mark Suszko
on Jan 31, 2012 at 2:43:18 pm
Or in the menus, it's Modify> make freeze frame. You can assign any duration you want to it. drag it to the bin and you have it as it's own source for multiple uses.
