Weird Audio delay in footage but only in Final Cut
Greg Burke
on Jan 30, 2012 at 4:48:13 am
Hey all I am currently Cutting a Movie Review I Captured the DVD footage I'm reviewing (That I OWN btw) using iShowu HD screen capture software. I then Converted it into proress for Final cut, It plays in quick time and all other players fine but when I take it into final cut the Audio is WAY off, I fix it and a couple time then minutes down the timeline it goes out of sync again? Im going into premiere so see if this solves the problem. But Why doe final cut do this?
I wear many hats.
http://www.gregburkepost.com
Dave LaRonde
Re: Weird Audio delay in footage but only in Final Cut
on Jan 30, 2012 at 5:38:48 pm
When you used iShowU, what was the sample rate of the audio? And the frame rate of the video?
You could also use MPEG Streamclip (free download) to convert the DVD video to a proper FCP editing codec with 44.8 kHz, 16/24 bit audio, too. It's probably better to do so in the long run.
Dave LaRonde
Sr. Promotion Producer
Tom Matthies
on Jan 30, 2012 at 9:43:14 pm
I'm guessing that Dave really meant to say 48kHz sampling rate rather than 44.8kHz.
E=MC2+/-2db
Dave LaRonde
on Jan 30, 2012 at 9:47:18 pm
Thanks for catching the typo. Or lapse of consciousness. Take your pick.
Dave LaRonde
Greg Burke
on Jan 30, 2012 at 10:18:12 pm
Right. Thank you. That worked.
I wear many hats.
