keyboard shortcut to enable a video filter to multiple clips ?
Steve Cornell
on Jan 27, 2012 at 8:15:16 pm
I've unchecked a video filter in all of my clips for playback purposes. Rather than open each clip into the Viewer and check 'on' the video filter, is there a way to do this for all of my clips in the timeline ?
Jerry Hofmann
Re: keyboard shortcut to enable a video filter to multiple clips ?
on Jan 27, 2012 at 9:23:21 pm
No.
Why are you turning off the filters in the first place? Maybe there's a better workflow to use...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Sascha Engel
on Jan 29, 2012 at 6:04:07 am
You could set your timeline to play base layer only,
and it will play it without the effect, just the naked clips.
Or you select all the clips in your tl and right mouse click, choose remove attributes-> Filters.
Then they are gone.
After watching just do "undo" and they are back on.
Sascha
