organizing footage by frame rate
Alex Korda
on Jan 27, 2012 at 7:40:23 pm
is there a way (software or program perhaps) to organize, sift, and otherwise sort through footage shot by frame rate? I use both 23.98 (24p) and 59.97 (60i) footage, the latter I use for slow mo purposes. Sometimes I miss a clip or two and they end up in FCP at normal speed looking different from the 24p footage. Does anyone have any tips/tricks/programs that can help sift thru the digital footage?
Thanks so much!
Jerry Hofmann
Re: organizing footage by frame rate
on Jan 27, 2012 at 8:57:55 pm
Sure. Sort on the "frame rate" column of the browser by clicking on it's name...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Alex Korda
on Jan 30, 2012 at 8:33:59 pm
What browser? In final cut or in mac os? That's the problem I'm having - there's no way to tell what the framerate is unless you look at each clip individually. Should I import them in to final cut and scroll through them that way?
Jerry Hofmann
on Jan 31, 2012 at 11:21:06 am
Yes, in the FCP browser window, you can find a frame rate column.... just sort on it by clicking on the column header.
Jerry
Current DVD:
