Final Cut Studio install issues
Bijoyini Chatterjee
on Jan 27, 2012 at 5:54:21 pm
Hi - I had to reformat my MacBook Pro (It has Leopard - 10.5.8) and reinstall all my applications. This included Final Cut Studio 2.
It seemed to work at first and I entered my serial number and related liscening information.
I can open some of the Final Cut Studio applications like Final Cut Pro, Color, Motion. However, Soundtrack Pro and Compressor don't recognize the serial number at all.
1. Does anyone have any clue as to why this is happening?
2. Also, there does not seem to be a way to uninstall and re-install Final Cut Studio. Does anyone have a suggestion?
Thanks a lot! Any help will be greatly appreciated.
Bijoyini
http://www.oniricaproductions.com
Jerry Hofmann
Re: Final Cut Studio install issues
on Jan 27, 2012 at 6:04:32 pm
http://www.digitalrebellion.com/fcsremover/
But before you do that, try moving the FCP system ID out of it's folder and re-enter the serial number to see if you can't fix it that way. It's in MacHD/Library/Application Support/Pro Apps/Final Cut Studio System ID Move the ID file out and keep it if you need to put it back or something.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Bijoyini Chatterjee
on Jan 27, 2012 at 6:07:58 pm
Thanks for your prompt reply! If that does not work, reinstall is my only option, right?
Thanks again,
Bijoyini
