Chromer keyer
Jayne James
Chromer keyer
on Jan 27, 2012 at 2:19:11 pm
Hi
I;d be very grateful if someone could give me some advice?
I'm using FCP 6.0.6. I am working on a special effects film using a green screen
I've cropped around the green screen and now need to remove the green screen from behind my subject. I click on the eye dropper tool and then the green screen of my subject on the canvas but absolutely nothing happens?
(its not a case of some of the green disappearing, nothing happens at all)
Is there something that I need to do after clicking on the green screen? a delete button or something?
or is it that I shouldn't be working on the canvas?
I think its probably some simple step I've left out but can't think what it might be
Any help would be grateful appreciated (apart from suggestions that I trash the preference files that is!)
Jayne
Mark Suszko
Re: Chromer keyer
on Jan 27, 2012 at 4:02:12 pm
Did you actually select the video track first by double-clicking on it?
Jayne James
Re: Chromer keyer
on Jan 31, 2012 at 5:24:21 pm
Thanks for the suggestion, yes I did select the video track.
However where I went wrong was in not dragging and dropping chromer keyer onto the video track
Once I did that it all worked fine :)
Jayne James
Re: Chromer keyer
on Jan 31, 2012 at 6:45:39 pm
Correction, you were absolutely right Mark, I also wasn't double clicking on the video clip
Doing that combined with dragging and dropping the chromer keyer onto the vid clip solved the problem
Thanks very much
Jayne
