Final Cut Pro - Problem exporting XML of Sequence "Critical Error"
Leigh O'Neill
on Jan 25, 2012 at 7:11:40 pm
Hi there,
I'm fairly new to Final Cut. I'm trying to export an XML of our picture locked sequence for finishing/color timing. Every time I try, I get "xml translation was aborted due to a critical error" about 20% in. The sequence is ProRes HD 4:2:2, about 1Hr 30Min. I've read of people having problems with XML while exporting large projects (over 50mb) but this is just a single sequence. Any ideas?
David Roth Weiss
Re: Final Cut Pro - Problem exporting XML of Sequence "Critical Error"
on Jan 25, 2012 at 7:17:30 pm
Do you have any events (clips) disabled in the timeline?
Any clips that have no reel numbers?
Clips named "untitled"?
The list goes on... But, you get the picture. Right?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Leigh O'Neill
on Jan 25, 2012 at 7:21:41 pm
I'm just coming on to the project so I'm not too sure, I'll scour through and get back to you. Much appreciated!
Jerry Hofmann
on Jan 25, 2012 at 7:21:30 pm
Sounds to me like about 20% into your sequence, you have some media files that are corrupt. Re build this area and give it another go. If the media file is really corrupt, you need to rebuild it by exporting it as a self contained movie file using the same codec as before, but turn on recompress all frames... but I'll bet that's the problem.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Leigh O'Neill
on Jan 25, 2012 at 10:19:24 pm
Thanks Jerry, I'll take a look at doing that. I'm now getting the error at around 9%, it seems to vary at what point it crashes.
As for the clip names, reel numbers...
Do Text layers, slugs..that type of thing need reel numbers?
No clips disabled or "untitled".
Thanks guys!
Leigh O'Neill
on Jan 25, 2012 at 11:55:01 pm
Jeez, nothing seems to work. Taken the sequence into a new project, copied its contents into a new sequence, took everything offline, tried it in separate parts. Even if I delete the first quarter of the sequence it still comes up with the error around 14%, sometimes 9% and sometimes 20%.
Very frustrating...
