fcp upgrade assistance
Mick Kalber
on Jan 25, 2012 at 10:43:26 am
G5 crashed. Rebuilt. Upon return, proects won't open in FCP... sez "File's format is too new for this version of the application."
I was running FCP 6.0.1 with system 10.5.8. Now FCP is 6.0. Upgraded AJA Kona to 6.1... didn't help. Don't see 6.0.1 upgrade for FCP on Apple's site. Suggestions?
Mick Kalber
Tropical Visions Video, Inc.
Hilo, Hawaii
Shane Ross
Re: fcp upgrade assistance
on Jan 25, 2012 at 3:19:36 pm
Run the SOFTWARE UPDATE from your system preferences. Look for the PRO APPS update. It should get you to 6.0.6, which is a far better version than 6.0.1 anyway.
Shane
Little Frog Post
Mick Kalber
on Jan 25, 2012 at 8:57:55 pm
and my 6.0.1 projects will still play on 6.0.6? appreciate the help, shane.
Mick Kalber
Hilo, Hawaii
Shane Ross
on Jan 25, 2012 at 10:19:44 pm
Yes...they will play. FCP will update the project file (actually ask if you mind that it does), but then it will work fine. Opening in later versions is easy. It's opening in earlier versions that tricky.
Shane
Little Frog Post
