LUT709 Question
abie silva
LUT709 Question
on Jan 24, 2012 at 8:37:15 pm
I have a client who provided ALEXA footage & wants to transcode from Apple ProRes 4444 to Apple Pro Res 422 (HQ) w 709 wrapper. I have done some the research & cannot find anything helpful; I've also taken a look at the ProRes white papers and no luck there either. Am i missing something? I'd like to know the workflow for how to do this. Any help will be greatly appreciated. thanks.
Shane Ross
Re: LUT709 Question
on Jan 24, 2012 at 9:01:18 pm
http://forums.creativecow.net/thread/8/1123398
Shane
Little Frog Post
Jeremy Garchow
Re: LUT709 Question
on Jan 25, 2012 at 12:07:39 am
I'd suggest using a Filter.
Glue Tools is good.
Pomfort also has one.
They are filters you will put on every clip in the timeline to transform to 709.
You can also build a LUT from Arri and use LUT Buddy (all free), but it seems to be really slow.
Are you planning on finishing in a dedicated grading application?
Jeremy
John Heagy
Re: LUT709 Question
on Jan 25, 2012 at 3:40:09 am
I've found the fastest way is to use Da Vinci Resolve Lite which is free. An 8 core MacPro with a single ATI card will apply a LogC to Rec709 LUT a bit faster than realtime sourcing and saving to our Xsan.
The one big caveat is it does not pass the audio.
John
