RT & Slow Motion in FCP
Jared Picune
on Jan 23, 2012 at 5:39:31 pm
I have some footage, 720p 60. Editing ProRes at 23.97 but want to mix the footage, real time and also in slow motion.
I've been copying the clip, then using Cinema Tools to re conform the clip to the new frame rate, which works well, but I'm wondering is there is a way to do this without having to have 2 copies of the clip.
Any thoughts?
Jared Picune CalDigit. Serious Storage.
Shane Ross
Re: RT & Slow Motion in FCP
on Jan 23, 2012 at 5:49:03 pm
Well, if you don't want to use the clip at normal speed, ONLY as slow motion, feel free to just conform the clip. You still have the masters backed up somewhere, right?
If you DO want to use it as normal speed, and slow motion, then you need to have two copies.
Shane
Little Frog Post
