Log and Transfer Clip numbering
adam burgess
on Jan 21, 2012 at 9:28:50 pm
Hello all,
Thanks for any help in advance...
I'm using log and transfer for AVCHD footage from a Canon HF10 camera. When I import a series of clips I get say numbers #1-45 in Log and Transfer. But when I import another or new volume of clips it doesn't name them 46-105 for example, it just starts again from #1. Obviously this is going to be a problem when I go to edit in FCP unless they are in different bins. But if I have to reconnect media it will confuse all the #1's etc. How can you set log and transfer to start the new batch with a continuous number/clip name sequence. It seems stupid not to be able to.. or am I missing something?
Shane Ross
Re: Log and Transfer Clip numbering
on Jan 21, 2012 at 10:33:02 pm
This isn't an FCP problem, this is an AVCHD issue. Every new card starts over at #1. And it can cause many problems.
Solution is to use the Custom naming options in the L&T interface.
Little Frog Post
© 2018 All Rights Reserved
