Apple Macbook Pro Running Slow! Final Cut Pro Playback and Rendering
lewis streete
on Jan 20, 2012 at 1:17:46 am
I have had my macbook pro (2.8ghz, 4gb ram) for 2 years now which i regularly took to school
and use everyday.
When using Final Cut Pro my playback is jumpy and rendering seems to take longer then usual even if it's the only thing running!
I thinks it's from repeat abuse in my bag which is highly possible
Even when using vuze and downloading stuff in the background i struggle to watch movies using VCL without lag...
Can someone let me know what possible issues could it be and whether a simple HD replacement or broken part replacement would fix my problem or should i buy a new one? (last resort)
Steve Eisen
Re: Apple Macbook Pro Running Slow! Final Cut Pro Playback and Rendering
on Jan 20, 2012 at 1:48:10 am
FCP likes playing back FCP friendly codecs (DV/DVCPro, DVCPro HD and all flavors of ProRes) from external Firewire 800 minimum hard drives.
Editing with h.264 and other long GOP (HDV) codecs really take a toll on playback.
[lewis streete] "I thinks it's from repeat abuse in my bag which is highly possible"
Very unlikely. Learning the correct workflow makes life much easier for the editor.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
lewis streete
on Jan 20, 2012 at 1:53:47 am
I can see what your saying but how could that be affecting me when I'm running Vuze and VLC and it is jumpy as well??
Jeff Meyer
on Jan 20, 2012 at 5:58:34 am
Repaired permissions lately?
lewis streete
on Jan 20, 2012 at 7:42:00 am
Yes I make sure i do it regularly...
Steve Eisen
on Jan 20, 2012 at 2:29:03 pm
[lewis streete] "could that be affecting me when I'm running Vuze and VLC"
Can't help you with non FCP related items. You'll have to go to the Genius Bar or email their support.
Steve Eisen
Vice President
Dave LaRonde
on Jan 20, 2012 at 4:00:53 pm
I haven't read if you're trying to edit without the benefit of an external FW 800 drive. Are you in fact trying to play back on the laptop's internal drive?
If this is what you're doing, this is bad practice. It may have worked for you in the past, but your footage may have been different than it is now (SD-HD) or it could be in an incorrect codec for FCP editing. It's a fact of life that hard drive get fragmented, making it tougher to get smooth playback. Finally there is the old maxim when editing in FCP: NEVER CAPTURE FOR FOOTAGE TO THE SYSTEM DRIVE.
As Steve eloquently puts it, "Learning the correct workflow makes life much easier for the editor."
Dave LaRonde
Sr. Promotion Producer
