HDV Decks
Chris Russell
HDV Decks
on Jan 18, 2012 at 10:38:25 pm
Hey guys,
I was just wondering what was the best HDV deck that was compatible with FCP 7 for capturing. I have tried a few decks already and they all seem to be compatible with an older version of FCP.
Jerry Alto
Re: HDV Decks
on Jan 19, 2012 at 2:03:34 am
Chris- I believe ALL HDV decks with firewire are compatible with FCP7. You have to be closed out of FCP BEFORE you connect the deck. Your deck settings have to be correct. Before you launch FC verify your Mac is seeing the deck (Apple menu>About this Mac>firewire). If you see your deck launch FCP and select the correct settings for deck control. If that doesn't work please return and list your symptoms.
Hope this helps.
Jerry
MacPro 2.93 Quad
FCP7
Sony Z-1
GV-HD700
