Crashes in Final Cut 7.03 with Snowleopard
Marc Puttkamer
on Jan 18, 2012 at 4:11:25 am
Having too frequent crashes- running our FCP system and Apple Pro Res files. We have recently upgraded our system- Final Cut 7.03, latest Snowleopard 10.6.8.; and we have current drivers/firmware for our Kona Card 3. We are running a 14tb RAID drive on the system- through SAS/SATA cables. 2 things have been happening lately- when we have a few timelines/sequences up at once- seems to cause first a flickering image- then and "out of memory" warning and crash;
also- what happens we'll get a big timeline/sequence up- or one with EX-1 footage on it- and it will crash straight out with no warning giving us an AJA Video output codec- - error warning.
Any ideas about what's happening here? Could this be Kona Card related? Thanks.
Michael Gissing
Re: Crashes in Final Cut 7.03 with Snowleopard
on Jan 18, 2012 at 7:38:46 am
Did you upgrade by installing over FCP6? Best advice here is to do a clean OS and FCS3 install on a new drive.
Also there have been issues for some people with graphics card and hard drive drivers going from 10.6.7 to 10.6.8 . The .8 upgrade was purely for FCPX and the apps store so if you can avoid this OS upgrade FCS3 will run better.
Marc Puttkamer
on Jan 18, 2012 at 11:30:44 pm
Thanks for that advice. We're in the middle of a big job right now, so a little nervous about changing operating systems. We've tried changing the AJA Kona card driver, and shutting off the Kona Card- external output- this seems to have helped for now....it's more stable.
Tom Asakawa
on Jan 22, 2012 at 11:41:48 am
I'm having the same FCP/Kona3 problem as Marc (OP) & other posts here;
Experiencing diminished performance & crashing out of FCP 7.0.3
crash log states ; "AJA videoOutput Plugin" at issue, although crashing without that particular line, too.
other issues; flash frames, black 'frames', failed renders, "out of memory" messages.
(multicam) sequence trt: 75 minutes
Sony XDCAM HD
FCP project file = 255mb
ANY help would be Much obliged...
tia,
-tom
Mac Pro 2.93 8-core 16GB OS 10.6.8
Kona 3
NEC3090WQXi
Quadro 4000
Caldigit HDPro2 8TB
Prism ADA8XR
Gen10
FCP 7.0.3
Smoke 2012 (10.6.7)
Media Composer
Kona 3 driver v10.0.1
Quadro driver v256.02.25f01
