Upresing 23.98 SD to 23.98 HD with Aja3 LHE and LHI thru final cut
jeff smith
on Jan 18, 2012 at 12:59:52 am
I want to know if it's better to use hardware and how to.
Shane Ross
Re: Upresing 23.98 SD to 23.98 HD with Aja3 LHE and LHI thru final cut
on Jan 18, 2012 at 5:31:35 am
Hardware. I have a tutorial on this.
creativecow.net/article/ross_shane/aja_kona3
Shane
Little Frog Post
jeff smith
on Jan 18, 2012 at 5:29:46 pm
thx, but your link doesn't work!!!
Shane Ross
on Jan 18, 2012 at 6:11:30 pm
Probably because I posted from my phone. Click on Tutorials, choose FCP. Limit to ones by me. You'll find it
Shane
Little Frog Post
jeff smith
on Jan 18, 2012 at 6:22:25 pm
found it, thx. my main problem is that im working in 525 23.98 sequence and trying to upres to 1920. fcp doesnt give an option to play out at 525 23.98. thoughts? thx again.....
Shane Ross
on Jan 18, 2012 at 6:46:09 pm
Ah. That's a problem. SD doesn't run at 23.98. There is no outPut video signal for it. You'd have to play out as 29.97, adding pulldown. But capture doesn't remove pulldown.
Best doing this via software then. compressor.
Shane
Little Frog Post
jeff smith
on Jan 18, 2012 at 6:48:17 pm
shit. ok. f me. any suggestions on compressor settings?
