Suddenly can't do Insert, Overwrite or Replace edits
Scott Herriott
on Jan 17, 2012 at 9:12:26 pm
I'm running FCP 7.0.3 on an IMac running OS 10.6.8.
About a half hour ago, my system crashed. Brought it back up and now any attempt at an Insert, Overwrite or Replace edit is met with an "Insufficient Content for Edit" message. I tested this with several clips where there IS sufficient content and, yet, the error message. I trashed my prefs to no avail. Any help would be greatly appreciated.
Thanks in advance,
Scott
jerry wise
Re: Suddenly can't do Insert, Overwrite or Replace edits
on Jan 17, 2012 at 10:17:51 pm
sounds like you might have in and out points on your timeline that are larger that any of your clips. what happens if you try fit-to-fill?
Scott Herriott
on Jan 17, 2012 at 10:53:52 pm
Jerry, that was it!
Many thanks for the help!
Dave LaRonde
on Jan 17, 2012 at 10:32:23 pm
Bad preferences, perhaps?
Dave LaRonde
Sr. Promotion Producer
david garcia
on Feb 2, 2012 at 1:15:53 pm
Hey Dave Laronde, it seems to me interesting what you said about bad preferences. It seems the guy who posted this solved his problem. Unfortunately, I couldn't.
I have the same problem: I have a clip and can't overwrite or insert, even when I have some space.
I tried it in a different new project. Same clip. Final Cut says: "for best perfomance your sequence and external video should be set to the format of the clips you are editing. Chance sequence settings to match the clip settings?
You think could have something to do with my problem?
I'm kind of new with FCP...
thanks!
Dave LaRonde
on Feb 2, 2012 at 7:23:11 pm
[david garcia] "You think could have something to do with my problem?
I'm kind of new with FCP..."
No one can say for sure with the information provided. As to the codec, we don't know the initial sequence settings were nor do we know the codec of the footage you tried to add to the new sequence.
As to the insufficient content, it could be that you just need to go over what you did step by step since you're new to this.
Dave LaRonde
