Smoothcam on FCP 7
Martin Robbins
Smoothcam on FCP 7
on Jan 17, 2012 at 3:15:30 pm
Hello, I've searched archive forums on here and apple.com but no luck.
I am attempting to use the smoothcam filter but it's not even attempting to analyze. I've tried on several clips in the project with no luck. However opening another project, it is working.
Sequence Settings for the project where it's not analyzing the clip are:
1440x1080
Upper(odd)
Editing timebase 25
Compressor Apple Intermediate Codec
Has anyone had any problems on specific formats, or is there another root to the problem.
Drake Hale
Re: Smoothcam on FCP 7
on Jan 17, 2012 at 3:17:49 pm
How long is the clip you are attempting to apply the filter to. Try and export the clip you want from the time line as a self-contained movie then re import it and try again. The intermediate codec should be fine, but you can also try ProRes
"It's all about keyframes"
Anonymous
2011 3.2GHz 27" iMac, Final Cut Studio 2, Adobe CS4
