Video in time line has turned to video black
Lowell Ing
on Jan 17, 2012 at 10:23:06 am
I am using final Cut pro 6 to edit a feature length documentary. I accidentally did something to a clip in the time line as it is video black in the final Cut pro timeline. The clip that it references in the capture scratch is the video file I want, picture and sound.
Joe Barta IV
Re: Video in time line has turned to video black
on Jan 17, 2012 at 7:19:19 pm
Check the Opacity in the Motion Tab. Sometimes when you are adjusting audio levels in the timeline using the rubber-bands you can accidentally pull down the opacity of a video clip. It then becomes completely transparent and would show up as black if there are no other clips under it.
Joe
