Capture skips first clip in Bin??
Jason O'Hara
on Jan 15, 2012 at 6:45:14 pm
I am having an ongoing problem capturing HDV from tape, occurring both in FCP 6 and FCP 7.
After logging a bin of clips and trying to capture, the tape rewinds to the second clip in the bin, captures it first then captures the rest of the bin in sequence until the end of the tape,..then the tape rewinds a second time to the beginning of the tape to capture the first clip in the bin last???
So the whole tape reminds twice in one capture unnecessarily. This occurs in 25% of capture attempts and occurs even with plenty of pre-roll on the first clip. It occurs with just bin highlighted or all clips in bin highlighted.
Any help is much appreciated.
Jerry Hofmann
Re: Capture skips first clip in Bin??
on Jan 15, 2012 at 7:02:44 pm
Odd indeed. Capture the first clip by itself?
The timecode isn't higher on that first clip? If so this would be normal behavior.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Jason O'Hara
on Jan 15, 2012 at 7:10:16 pm
indeed, capturing first clip by itself is my work-around, but then when setting up the capture for the remainder of the tape, it sometimes does the same thing again, skipping clip #2 and starting with clip #3, only to rewind again at end to capture clip #2.
In this particular case my in-out points are:
clip #1 00:00:21:00 - 00:01:10:00
clip# 2 00:01:29:00 - 00:03:16:00
clip #4 00:03:42:00 - 00:05:04:00
Jerry Hofmann
on Jan 15, 2012 at 7:11:27 pm
There is no setting to change... might try trashing prefs?
Or capture the first clip, then batch it again with the others... when it rewinds, stop the capture.
Jerry
David Roth Weiss
on Jan 15, 2012 at 7:19:16 pm
I've always found that capturing the entire HDV tape is the only way to fly seamlessly. Capturing individually logged clips is subject to the whims of the HDV gods, and invariably save no time whatsoever.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Jerry Hofmann
on Jan 15, 2012 at 7:45:04 pm
My students worked a lot in HDV pre AVCHD.... I've never worked much with it otherwise, but tapeless cameras sure make all of this easier.
Jerry
Current DVD:
David Roth Weiss
on Jan 15, 2012 at 8:16:42 pm
I worked with HDV a fair amount and grew to dislike it the more I did. Its color space is very limited, with very limited latitude, and it does not hold up particularly well when encoding for DVD or web delivery unless it's perfectly exposed in-camera. It was never really designed for professional use, but as we all know, the lines between pro, prosumer, and consumer have been blurred beyond definition.
David Roth Weiss
Los Angeles
