RED, Davinci, After Effects, and FCP/Premiere workflow
Brandon Morris
on Jan 15, 2012 at 5:43:14 am
What is the best workflow for RED footage to Editorial to Effects to Davinci?
Is it worth to switch from FCP to Premiere to be able to edit R3D and skip transcodes?
And also be able to go straight from Premiere to After Effects back to Premiere with out rendering?
Are there any downsides to using Premiere over FCP?
I feel like switching to Premiere will save a lot on hard drive space by skipping transcoding and select renders for vis-fx.
Brandon Morris
http://www.brandonmorris.com
Canon T2i
13" Macbook Pro (Mid 09) 8GB RAM 10.6
