fcp problems after importing effects
rich pearson
on Jan 11, 2012 at 6:46:35 pm
Hi
I am running fcp 5.1 on a G4 Dual 1GHz powerpc. I recently added a Bad tv, smooth cam effects bundle to the fx plug folder and managed to use the effect in my timeline. All was fine untill I came to render and I got a 'general error' message. I have trashed and deleted the effects folder, re-started the fcp, re-booted. Nothing will render in the timeline including unrelated media.The Bad tv effects shows up in the fcp filters menu as well.
Any suggestions on what I can do please.
Shane Ross
Re: fcp problems after importing effects
on Jan 11, 2012 at 6:56:47 pm
Those are pretty intensive filters. I believe they require an Intel Mac to be able to render. I know a friend with a G5 that cannot get smoothcam to work.
I thought they were part of FCP 6 and 7...not sold separately. How did you get them separately?
Shane
Little Frog Post
rich pearson
on Jan 11, 2012 at 7:53:06 pm
Hi Shane,
thanks for the reply. I didn't realise that they would'nt work with my set up. I got the link from an old 2009 forum posting. I should have checked the version that was running them. An experiment gone wrong.
do you have any suggestions as to how I can resume normal FCP operations please?
Shane Ross
on Jan 11, 2012 at 8:37:12 pm
Trash your preferences....
#44: FCP acting weird - Trash Prefs
Shane's Stock Answer #44: FCP acting weird or unusual. Just not like is normally should
If the program was working fine, and now isn't, or just isn't working the way it should, the first things to do are:
1) Trash your FCP preferences. Download the Preference Manager from Digital Rebellion: http://www.digitalrebellion.com/pref_man.htm
http://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
2) Open the Disk Utility and Repair Permissions.
3) Shut down for 10 min. Go for a quick walk around the block and get SOME exercise today. Come back, turn on the computer and see how things are.
4) (optional) Do the Hokey Pokey and turn your self about. Results may vary.
Shane
Little Frog Post
