DSLR work flow
Roli Rivelino
DSLR work flow
on Jan 11, 2012 at 5:18:13 pm
Hi I'm about to start my first DSLR project in the next couple of days and I'm wondering if there's anything in particular I have to worry about.
I know there are sync issues with DSLR, but this is a music video so that shouldn't be a problem, right?
Any tips greatly appreciated.
many thanks.
http://www.rolirivelino.com/
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Dave LaRonde
Re: DSLR work flow
on Jan 11, 2012 at 6:03:51 pm
As long as you know enough to use proper techniques to transcode the footage to ProRes 422 prior to editing, and I bet you do...
and you DO NOT expect to use audio from the camera...
and you're well-versed in the workflow for an external audio recording device, if you use one...
and you maintain a consistent frame rate at every single stage of the workflow...
...you should be okay.
Dave LaRonde
Sr. Promotion Producer
Shane Ross
Re: DSLR work flow
on Jan 11, 2012 at 6:24:48 pm
THis is the tapeless workflow for FCP:
Tapeless Workflow for FCP 7 Tutorial
You can also transcode the DSLR video with MPEG STREAMCLIP, or COMPRESSOR.
As for "I don't need to worry about sync because this is a music video"...yes you do. CD's on set play back at a slightly different speed than imported into an NLE. 44.1khz (CD) vs 48khz (NLE) is one reason. THe CD player playing back at possibly a different speed (I have seen this more than once) is another. Plaing back from a digital player might help.
Just shoot a test first...play back from a player and shoot with a DSLR...just something in the office. Import it and see what happens. ALWAYS TEST before you begin a workflow you have never done before. Iron out issues before you spend a lot of money on production only to find those issues might be crippling.
Shane
Little Frog Post
Roli Rivelino
Re: DSLR work flow
on Jan 11, 2012 at 6:58:10 pm
Thanks a lot guys, the footage has already been shot and I'm being brought in on a rescue edit and was wondering how DSLR differs from other tapeless workflows.
I suppose (hope) they have a fully synced (AC3/Mp3.
Once again many thanks.
System
8Gb RAM
Equipment
Firestore FS-100
Dave LaRonde
Re: DSLR work flow
on Jan 11, 2012 at 7:28:30 pm
[Roli Rivelino] "I suppose (hope) they have a fully synced (AC3/Mp3."
I'll bet you're also aware that compressed audio is no good in FCP, and should be converted to aiff 48kz. Wav files are OK, too.
Dave LaRonde
Roli Rivelino
Re: DSLR work flow
on Jan 11, 2012 at 11:35:52 pm
ah yes, thank you Dave.
System
8Gb RAM
Equipment
Firestore FS-100
