Changing 25fps footage rendered to 30Fps back to 25fps again...
adrian kelaty
on Jan 10, 2012 at 3:38:32 pm
Hi there
I shot a four hour wedding video at 25fps (50i) and I erroneously put it into a sequence which was set to 30fps. When I export it at 25fps, it goes horribly out of sequence. Can I reconvert it to 25fps again?
Oh yes, and I've tried pasting it into a 25fps sequence. It wasn't a good idea....
Adrian
Shane Ross
Re: Changing 25fps footage rendered to 30Fps back to 25fps again...
on Jan 10, 2012 at 5:23:31 pm
YOu are going to have to copy and paste into a new proper sequence, and then fix all the gaps that appear. There will be a lot of fixing to do.
Shane
Little Frog Post
adrian kelaty
on Jan 10, 2012 at 6:25:22 pm
Hi Shane
Thanks for your reply. I was fearing that would be the case!
Oh well :(
Kind regards
Adrian
