MXF files from EX3 to FCP7 - best workflow
frankie caradonna
on Jan 7, 2012 at 7:14:14 pm
Hello guys
I've got these .mxf files from sony ex3
Trying to figure out how to manage them in fcp7
I see there some expensive mxf/qt converter for mac but I'm looking for a cheap but correct solution
I read of this trick but I can't verify how professional it is and if it works:
- import the mxf files into your fcp project in the same way you do with mov files
- the software will obviously tell you they're not good and bla bla bla...
- with the Media Manager tool re-compress them in appleprores422LT into a new project
anyone tested this workflow?
does it work?
any suggestions are more then welcome!!!!
thank you in advance
John Fishback
Re: MXF files from EX3 to FCP7 - best workflow
on Jan 7, 2012 at 8:19:55 pm
If you Google you'll find posts about EX3 workflow with FCP. Check this out.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
