Why converting uncompressed SD video to ProRes flips the field dominance to upper?
Jeff Cotten
on Jan 6, 2012 at 7:41:04 pm
When I convert a SD video file to ProRes 422 using compressor, it outputs a file that is upper field first. The uncompressed file is lower field first. I checked the "Frame Controls" setting in compressor and it is set to "Same as Source". Thanks for any info.
Shane Ross
Re: Why converting uncompressed SD video to ProRes flips the field dominance to upper?
on Jan 6, 2012 at 8:04:34 pm
HD video is upper field...SD is lower field.
Shane
Little Frog Post
Jeff Cotten
on Jan 6, 2012 at 8:25:06 pm
Yes - it's changing the SD video to upper field. It's not keeping it lower field for SD.
Shane Ross
on Jan 6, 2012 at 8:47:00 pm
Ohhhh...you are making it ProRes SD? And it is switching the field order?
Shane
Little Frog Post
John Pale
on Jan 6, 2012 at 8:48:50 pm
What is your SD frame size ?
720 x 480 or 486?
Jeff Cotten
on Jan 6, 2012 at 8:55:58 pm
It's 720 x 486. Would that make a difference even if it was 720 x 480?
Ian Liuzzi-Fedun
on Oct 12, 2012 at 4:03:37 pm
Any answer on this?
Jeff Cotten
on Oct 12, 2012 at 4:33:03 pm
No. I still don't know what's happening in this processs.
This is happening to you too?
