FCP7 Canvas defaults to ALPHA channel???
Dustin Rosemark
on Jan 6, 2012 at 6:58:21 pm
Some how the Canvas has started defaulting to ALPHA channel (instead of RGB). How do I set it back to RGB? It is getting annoying, and I would rather not keep an eye on this.
Bret Williams
Re: FCP7 Canvas defaults to ALPHA channel???
on Jan 7, 2012 at 5:43:38 am
It's right there in the canvas pulldown menus. There are hot keys. You're probably inadvertently hitting one.
Eric Schlenker
on Jan 20, 2012 at 5:46:19 pm
Same thing just happened to me, SO ANNOYING! I'm pretty sure I fumbled a shortcut but I have no clue what keys I hit to switch it back. The canvas window now defaults to the white alpha for every sequence until you switch it back to RGB. Easy enough to switch, but if I have to do it every time I open a sequence it'll drive me mad!
I'll probably get nothing else done on this project until I rat out the varmint shortcut and get it back in order.
