Export to quicktime cuts off half the movie.
Anton French
on Jan 4, 2012 at 11:51:18 pm
This is a weird one, if i export directly to quicktime (not via conversion) and I use the same settings as the sequence, fcp only exports the front half of the film? No markers on the timeline or i/o points. Any ideas anyone?
fcp 6.6
PPC G5 dual 2.7
anton
Dave LaRonde
Re: Export to quicktime cuts off half the movie.
on Jan 5, 2012 at 7:00:25 pm
Before you get concerned, do the easy stuff first:
If you haven't turned off your machine for a while, try it.
Repair permissions & run Disk Warrior if you have it.
Trash FCP preferences.
If none of those work, that's when you might want to think about reinstalling.
Dave LaRonde
Sr. Promotion Producer
Anton French
on Jan 5, 2012 at 7:10:05 pm
Thanks Dave, appreciate your response.
will try those things
anton
