Moving project from FCP 6 to FCP 7
Smith Glover
on Jan 3, 2012 at 1:23:55 am
I am currently running FCP 6.0.6. I have a client that needs a project done in FCP 7. I can't currently upgrade my machine, for various reasons. My question is- if I edit in FCP 6, and then do a final pass in FCP 7 on someone else's machine (saving it as a FCP 7 project), will this cause any issues? In other words, does doing a project in FCP 6 and then saving it in FCP 7 create the same project as if it were done in FCP 7 the whole time? I want to make sure that I give my client what he wants.
Shane Ross
Re: Moving project from FCP 6 to FCP 7
on Jan 3, 2012 at 2:09:05 am
Going from 6 to 7 is easy. You won't even notice a thing.
Going from 7 to 6...that's the tricky part.
Shane
Little Frog Post
Barbara Keating
on Mar 20, 2012 at 4:58:51 pm
Hi guys, I had a pal call today saying they can't play their sequence having upgraded from FCP6 to 7.
Instead of the sequence clips being blue, they are white and won't play. Audio is OK.
The footage was originated on a JVC 111 and is MPEG 2 and was being edited natively in FCP6.
Snow Leopard10.3.6
Apparently it takes hours to open, and it seems to be rendering all the time.
Any clues ?
Steve Eisen
on Jan 3, 2012 at 2:12:18 am
You can natively open an FCP 6 project in FCP 7. This will not cause any issues. The only way to open the FCP 7 project back in FCP 6 is by using XML export.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Smith Glover
on Jan 3, 2012 at 2:17:26 am
Thanks to both of you- that's what I was hoping.
