splitting audio tracks
bradley morales
on Dec 29, 2011 at 3:56:08 am
I have a Panasonic HFC 150. An audio guy sugguested that when I shoot, a good way to cover any differences in audio levels, I should turn the left input level bellow the midpoint and the right input level above the midpoint.
When I transfered the clip to the FCP timeline I was unable to separate the audio tracks.
Example, I was recording conversation, but then with the same audio settings some guys sang into an amplified mic. So now my right audio is too high and the left is right on. I want to eliminate the right track (track 2) and duplicate the left track (track 1) which I will then put in its place.
how do I do that?
Justin Keats
Re: splitting audio tracks
on Dec 29, 2011 at 11:57:55 am
Select clip, go to 'Modify' menu and untick 'Stereo Pair'. Did that work?
bradley morales
on Dec 29, 2011 at 6:20:22 pm
worked perfectly, thanks
Jerry Hofmann
on Dec 29, 2011 at 1:30:53 pm
Select the clips in the sequence then Uncheck "stereo pair" in the Modify menu.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
bradley morales
on Dec 29, 2011 at 6:21:02 pm
