NTSC to PAL
don horwitz
NTSC to PAL
on Dec 27, 2011 at 8:59:24 pm
Hi everyone,
I need some help. I have a :60 spot (1920x1080, NTSC, 29.97) edited in fcp. The client wants a version in PAL MPEG-2 720x576 16x9,
25fps for broadcast in the UK. Any suggestions on the best route to take for this?
Don
Don Horwitz
Dave LaRonde
Re: NTSC to PAL
on Dec 27, 2011 at 10:23:38 pm
Do the frame rate conversion first. Use Compressor if you want it free, Twixtor if you don't mine spending a few hundred bucks for good frame rate conversion software, or a production house where you'll spend about four figures.
As to the PRECISE delivery specifications for mpeg2 in the UK, you will have to contact the organization to which you'll deliver the file.
Dave LaRonde
Sr. Promotion Producer
