Trouble exporting from FCP to XDCAM PDWU-1 SD
daniel ladeira
on Dec 26, 2011 at 8:30:56 pm
Hi there,
two things, I have to export to XDCAM disk using the PDWU-1 deck, two medias, one in HD and the other in SD
the one in HD i use HD422 50mbps audio 8CH, 24bits. No problem with thatm working nice.
But... the disk in SD, which i have to use IMX40, 40mbps, audio 4CH,24bits, i just can't do it because of the audio. i only get 8CH 16bits. Tried everything i know with no sucesss. Any clue?
The timeline is set to 24bit depth, the audio output is set to 4 outputs, 2 channels each, dual mono (if i set it up to 2 outputs, 2 channels it wont work)
I do the same i did for HD disk, but the HD disk i get the correct 8CH, 24 bit, and the SD i only get a 8CH 16bit.
wonder if anyone can give me a tip
thanks for ur attention
Daniel
